White smoke coming from exhaust
2001 Ford Explorer Sport 6 cylinder 4.0 liter
White smoke and water just recently started coming from my exhaust. what could be wrong?
question
Does it go away after it warms up after a few miles of driving?How is the coolant level?In cold weather it is normal for white smoke to come out as steam untill the exaust system warms up and drys out.
However if after lets say a 20 mile drive white smoke comes out you have a problem.Head gasket leaking into one of the cylinders.If this is the case you can have coolant tested for combustion by products to confirm it or a commpression check will also tell.
If you have had this problem for a while you can also check plugs and the one that looks diffrent then the other 5 that is the cyl.Also you can look into the radiatior cap with engine running and look for air bubbles.
get some sleep
Like I said I would not lose any sleep over it It is probbably cold outside and it is just condensation.
Look around when you drive you can spot the drivers that just started driving by the white smoke coming out of the tail pipe.If it does not stop then worry about it.
white smoke ?
