92 Mazda b2200 truck
Old 12-02-05, 07:12 AM
avianacres
My 92 Mazda b2200 truck has white smoke (which smells) coming from exhaust initially when you start it until the vehicle warms up (which takes forever-usually a couple of blocks). From that point on there is no smoke and no smell.
Old 12-02-05, 07:22 AM
might be ok
The weather is getting colder and it is normal to see white smoke from the tail pipe till engine warms up.(condensation).However if white smoke does not stop after a long drive like 20 miles I would start looking at why.Also how is the fluid in the radiatior?If you have to keep adding you have a problem.Also whith engine hot if you look into the radiatior and see air bubbles that is a problem.
If you have a steam engine and it is billowing white smoke and I mean gushing out steam you have a problem.
Head gasket would be the problem to the problems listed.
Dont jump to conclusions till you look and see if it only smokes on cold days and for a short time.
