90 Merc Wagon failed emission test
Old 12-05-05, 08:57 AM
2 years ago, you were most helpful in assisting with the diagnosis of a bad EGR valve.
Well, I think the problem this time is something else as the NO readings were OK.
Here are the results from Jan 8, 2004 as well as Dec 2, 2005:
Jan 2004
Test-------Limit---Reading----Result--Limit---Reading---Result
HC ppm-----101-----60-------Pass-----98------68------Pass
CO%-------0.56----0.00-------Pass----0.60----0.00-----Pass
NO ppm----0757----197--------Pass---0690-----250------Pass
RPM----------------1402------Valid-------------1118----Valid
Dilution--------------11.1-----Valid-------------11.3----Valid
Dec 2005
HC ppm-----0055----69-------Fail-----0060-----189------Fail
CO%-------0.22----0.01-------Pass----0.32----2.85-----Fail
NO ppm----0720----104--------Pass----700------82------Pass
Dilution--------------11.3-----Valid-------------12.3----Valid
The values on the left are @15MPH, while the values on the right are @25MPH.
The car is a 1990 Merc Colony Park Wagon (5.0L V8, AT) with 175K miles
No major work done in the past 2 years, but used only once per week on average for short trips (one commute of 30 miles RT, plus hauling building materials from HD/Lowes).
Oil changed every 3K miles or twice per year. Due for next one by 1/1/06.
Replaced air filter while in line for inspection.
Any suggestions, please?
thanks
Update on 12/19:
I found a fouled plug and replaced it, and ran some Chevron fuel system cleaner through. Also ran a can of TB cleaner through, plus replaced the PCV breather filter thing. Took it back for a reinspection. Failed again, but getting better:
The HCs were down to 68 and 72, respectively. Everything else passed fine.
Any suggestions, please? How can I get the HCs down further?
Old 12-19-05, 02:38 PM
See update to message above. I would appreciate suggestions. Thanks.
