1997 GMC Jimmy
Old 12-06-05, 01:38 PM
1997 GMC Jimmy
Daughter has a '97 Jimmy 4x4. Pushbutton 4 wheel drive. Light on dash comes on for 4 high & 4 low & your can hear something click on front of vehicle when trying to put in 4 wheel but front wheels not engaged. Worked fine last winter. Had it checked quickly after work at garage & said no codes came up. Any ideas as to what to check or what could be wrong? Dave
Old 12-06-05, 08:22 PM
More than likely the encoder motor. Try this, it is a short fix, take out the TCCM fuze for about 5 min. Then try the push button, it should work until the motor fails again. Costly part @ the dealer, look on e-bay, not so costly, only takes 30 min to replace.
Old 12-07-05, 03:04 PM
GMC Jimmy
Thanks for the info! I'll try it & let you know how I make out. Dave
Trackbacks are On
Pingbacks are On
Refbacks are On
