Heat only when excellerating
Old 12-07-05, 09:37 AM
Saturday Mech
My 2002 Dodge Stratus only has cabin heat when I am excellerating, no heat when stopped. Does anyone know what this is? Engine temp acts normal
Old 12-07-05, 11:39 AM
The blower still blows? It just blows cold at idle?
Old 12-07-05, 02:58 PM
HairyKnuckle's Avatar
Thermostat going bad possibly.
Old 12-08-05, 05:21 AM
Saturday Mech
Yes still blows air, just cold
Old 12-08-05, 05:29 AM
I'd look at:
Low coolant
Loose belts
Water pump on the way out
Old 12-14-05, 06:48 PM
Saturday Mech
Coolant seems to be fine, belts ok. I read about "burping" the system for air locks, but how can I do that if there is no access to the radiator? Only the reseviour
Old 12-15-05, 02:38 AM
New guy's Avatar
What engine?.
Old 12-15-05, 10:36 AM
thiggy's Avatar
Heat only under accelleration makes me think of a vacuum leak or defective vacuum controlled heater door. If there was a bad thermostat, you wouldn't have warm air only when you stepped on the gas, likewise for the other guesses. I can't think of anything else which could make a significant difference in the cabin heat from accelerating other than a vacuum issue. I assume from the OP, that when they let up on the gas, the heater starts blowing cold air or none at all.
Old 12-16-05, 08:59 AM
Some engines have a small nut (valve) on top of the thermostat housing. If you have one, that is where you bleed air out of the system.
