sputter shimmy shake
Old 12-09-05, 06:10 AM
COREY HALLBERG
my 1993 jeep has been acting up. it starts fine but after a few minutes it sputters and then a check engine light comes on. when driving it seems to cutout for a second and stutter a little bit also when i deselerate the rpms drop to about 300 and it sometimes dies. ive been told it could be a vaccuum or fuel problem. any ideas?
Old 12-09-05, 03:12 PM
the_tow_guy's Avatar
Going to need to find out what codes the check engine light is setting. AutoZone will read the codes for free, but not sure if they can do OBD-I or not.
There's a procedure here: http://www.jedi.com/obiwan/jeep/dtc.html
that's suppose to work for the OBD-I stuff.
Get the codes and post back what you find.
Old 12-15-05, 02:59 PM
COREY HALLBERG
If Im Reading The Codes Correctly Its A 24 I Think Thats A Throttle Position Sensor. Any Clues
Old 12-15-05, 07:59 PM
A 24 code would be "flash..flash.............flash..flash..flash..flash".
Seems to me that I recall the throttle positioning sensors have been somewhat problematic on some years of Jeeps.
Several options:
1. Pick up a repair manual that will have the specific troubleshooting proceudres for that code.
2. Roll the dice and replace the TPS.
3. Take it to your favorite mechanic.
