92 dodge caravan se
Old 12-09-05, 03:37 PM
johnhancock
92 dodge caravan se
the heater blower motor stops like you turned it off when you go up a incline or acell fast when you let off gas it starts to work again it is not just switching from vent to defrost it stops blowing alltogether and all you get out of vent is gravity heat if you can give me any tips that would be great . thanks john
Old 12-09-05, 07:30 PM
G
My first guess would be a loose wire or connection. Could be a hot wire or a ground connection. Start it up. and with the heater running, wiggle any wires you can under the dash and near the blower motor.
