noise
Old 12-11-05, 08:42 AM
tia
noise
Can anybody tell me what a power steering pump - belt sounds like when it is going, does it make a whinning humming sound and is it constant or happen off and on?
Old 12-11-05, 07:41 PM
v8driver's Avatar
if its whinning, i would check the fluid first.
Old 12-11-05, 10:14 PM
G
After checking the fluid, I would start the engine,and with the car in neutral, turn the steering wheel left until it won't turn any further, then turn it right until it won't turn any further. Repeat several times. This will help bleed out any air which may be in the lines.
