95 Probe Major oil problem. Engine no start.
Old 12-12-05, 07:30 PM
tr_moser
If anybody out there could help me out and point me in the right direction to getting this thing repaired I would be much obliged.
When I recently purchased a 95 probe it was a bit smoky so I replaced the catalytic converter and the O2 sensors which fixed that problem. For the past few months it has been burning a lot of oil and leaking a bit as well. It has also been making a clicking sound when started out in lower gears. The other day the clicking turned into a grinding when I pulled off the freeway. I figured it has to be really low on oil so before I took off I put some oil in it until I could get it home. I got about 3 miles until it started with the grinding again when slowed me to a halt. When slowing down I let out the clutch a bit in a higher gear and it had a bad jerk and continued with the grinding (sounded like it was from the pistons.) We pulled off and walked to a gas station to get some oil. I put 3 quarts in and it all poured out the bottom. When I tried to start it just made a click like the battery is dead but I have had that tested since then and the batt is good. Now that it is home we put some more oil in it and it did not leak at all. I checked it and the oil is staying at 3/4 full. It will still not try to crank over. The oil appears as if it is coming from around the top of the oil pan or the oil cooler. Tomorrow I am going to clean the engine to better diagnose the oil leak but I can still not get the car to crank at all. All wiring should be good as well as the starter.
Thank you very much,
Ty Moser
Old 12-12-05, 07:35 PM
chevyastro4x4's Avatar
sounds like you put a piston though your oil pan or block
Old 12-12-05, 09:39 PM
v8driver's Avatar
same here, engines frozen up, i'd take a look at the oil pan, hole with indentions out is connecting rod, in and something hit it. pretty much sounds fried, sad to say
Old 12-13-05, 06:48 AM
I also think you need a new engine. If you are planning to keep the car a while, it's well worth it to put in a Jasper. I had one put in my Escort 4 years ago. Cost $4000, but worth it.
Old 12-13-05, 07:04 AM
tr_moser
I have not seen any bumps or dents in the oil pan and when i was slowing down all my pistons were still moving. I think i am going to bring it to a mechanic today and have them check it out.
Thanks
Old 12-13-05, 07:54 AM
let us know what the problem was.
Old 12-15-05, 08:44 AM
tr_moser
Ok, so the engine is seized. I am now in search of a new engine. I have found some engines from Japan for around 500 bucks. They all have less than 50k on them. They are a V6 2.0L but compared to the 2.5 in it now they put out 170hp compared to my 165hp. This engine is supposed to fit perfectly. What do you think? Any suggestions on where I could find a motor for cheap?
Old 12-15-05, 08:56 AM
ttry some junk yards or ebay, i've got some off of ebay
is the whole motor seized
Old 12-15-05, 09:38 AM
Japan engines
I have heard about the low miles Japan engines the only thing I would worry about is emmisions,They dont have the same as we do and some of the engines might not have all the holes to bolt up USA emmisions equipment.
Something to think about.
Old 12-15-05, 12:02 PM
tr_moser
Well, probably not a good idea but we pushed it and i dropped it into 2nd, 1st, and reverse and it skidded to a stop every time. It is leaking both anti freeze and oil.
That japan engine is suppossed to be a "Direct bolt up" to the probe.
Old 12-15-05, 01:37 PM
its history
Sounds like the engine you now have is history .Check into the Japan engine I am sure they are good just not sure about all the accessories are compadable.Maybe you can ask them first.
I am sure the motor mounts bolt right up but what about if it has a EGR valve I dont know if one is required in Japan and if not then you wont have one either because the engine will not be machined for it.
Old 01-15-06, 02:26 PM
prope engine
I have a 2.5 V6 oout of 93 Ford Probe. sell cheap if it will help.please E-mail me.If you need my e-mail let me know.
Old 01-15-06, 02:36 PM
Angry montero problem
hAVE 90 MONTERO, NO SPARK. RUNS FUEL STREIGHT THROUGH TO OIL, AND INTO AIR CLEANER.iHAVE CHANGED FUEL PRESSURE REGULATER,STILL DOES IT`S THING. wHY? CAN SOMEONE HELP
Trackbacks are On
Pingbacks are On
Refbacks are On
