How much play in the steering?
Old 12-15-05, 06:50 AM
Bubba Bob
Hey Guys
How much play should be in my steering? With the car off and jsut sitting still and can turn my wheel about 20 degrees both ways with no effort and with little effect on the wheels. This is EXTREMELY irritating while driving.
ALso, is creaking while steering at low speeds normal for winter?
Thanks
EDIT:
95 Ford Escort w/ 130k miles. New CV joints. (700 miles or so)
Old 12-19-05, 08:30 PM
Bubba Bob
Tie rod ends needed replacing. Thank God for the Sears card.
Old 12-20-05, 07:40 AM
I
The outer tie rod ends are a real easy DIY project. Easier than an oil change. After you have done it once, then you are an expert (it's that easy). If you need inner and outer tie rod ends then I am not sure if it's DIY. Either way you need an alignment afterwards. If you really went that far on the roiginal tie rod ends it's amazing that they didn't break completely on you. Get MOOG replacements, they will have the grease fitting on them. It will make a big difference!
Old 12-20-05, 07:41 AM
I
Check out http://www.feoa.net (Ford Escort enthusiast site).
Old 12-20-05, 05:08 PM
Bubba Bob
I must have had "end" on the mind last night. I had the tie rods replaced. It might be a DIY project, but they have nice hydrolic lifts, Ive got a jack and blocks
Anyway, thanks for the link. Im a member of FEOA, but figured Id check out these forums to.
