99 saturn ignition
Old 12-26-05, 09:52 AM
P
99 saturn ignition
We have a key broke off in the ignition. How can we remove the ignition?
Thanks!
Old 12-26-05, 10:27 AM
ksion15
Might work
if you are able to still turn the ignition (with screwdriver or something) this might work. remove the steering column shroud. turn the ignition to the ACC position. there is a hole on top of the ignition housing. depress the button inside of the hole, while pulling out on the lock cylinder with vise grips or something. this might work.
