Car Window Replacement Question
Old 12-28-05, 12:58 PM
Fortino
I've reset my car door window before a few times. A guy who works in the car window business recommended an adhesive to use in the brackets that hold the car door window in place as it goes up and/or down. It was black and sticky and came in a tube to be dispensed using a gun. Any ideas what this adhesive might have been? OR What is your recommendation for an adhesive to use in this situation?
Old 12-28-05, 05:24 PM
CRBENDER
Window glue
I've had good luck with 3M products, mostly the '847' weatherstrip adhesive, I've used other numbers and one is black, make sure you follow the directions as shortcuts result in failure.
CB
