soft brake pedal Grand cherokee
Old 01-02-06, 05:49 PM
1995 Jeep Grand Cherokee LTd, 5.2 L V8. with ABS.
the brake pedal is soft and will slowly sink to floor.
Put new front pads on a year ago. Brakes worked fine until a couple months ago when I noticed the pedal sinking to the floor. Here's what I've tried so far with no success:
1. Bled the brakes
2. Installed new master cylinder
3. bled the brakes again.
4. also checked the lines for leaks, none found
any suggestions?
jim
Old 01-03-06, 06:09 AM
Check the rear brakes and wheel cylinders if they are drums in the rear.
Old 01-03-06, 07:46 AM
They seem to be OK. Is there something specific you'd suggest I look for?
thanks
j
Old 01-03-06, 02:27 PM
sounds like air
Sounds like you have air in system due to a possible leak.I would reinspect all hoses.and pull back all dust boots around wheel cylinders and look for fluid.Pay paticular attention to were there are fittings (connections).
It really sound like a classic leak in the system.Even a very small one can cause this.
Did you bench bleed the master before you put it on?
