95 1500 ram 4x4 need lotsa help
Old 01-03-06, 03:09 PM
Arrow 95 1500 ram 4x4 need lotsa help
i went 4 wheelin and hit a whole that was deeper than i thought and ended up suckin water thru the intake what can i do to get my truck runnin again plz help
Old 01-03-06, 04:16 PM
Lugnut's Avatar
Just curious. Are you saying that you submerged your engine in water to the point of water entering the air cleaner?
Cause if you did not do that, then I doubt that much water would splash up and get sucked thru the paper air filter element, no matter how deep the hole was.
Old 01-03-06, 06:22 PM
New Member
I would pull air filter apart to dry, pull plugs, spray wd-40 into cylenders, crank engine, spray wd-40 again, crank engine and put back together. This has worked for me several years ago. Good Luck!!!
