Buick,LeSabre 1995
Buick,LeSabre 1995
A 1995 Buick LeSabre,has radio volume control up and down also scan buttons in center of steering wheel,but they don't work.Can anyone tell me why?Cecil.
Do you still have the orignial stereo in the car? If so, there are (1) or (2) 2amp, or 3amp fuses at the base of the steering column for the steering wheel controls. Check them. It is also possible that there is a bad wire in between the fuses and the switches. Could also be the switches themselves.
If you have an aftermarket stereo, or a different model stereo, the switches will not work.
