locked out
locked out
I have a 1994 Mercury Cougar that wants to keep me out. The door locks do not want to unlock from the outside. Is this a job for the body shop/mechanic or something I can do with basic hand tools? I'm kinda lost on how to remove the door panels to gain access to the lock works. Any help?
Can you clarify "locks do not want to unlock from the outside"? Is this with key, door handle, or key fob?
Any repair would involve removing the interior door panel. It's all nuts and bolts with some prying on the edges.
The grease in the latch mechanism inside the door has probably dried up and turned hard. It's a big job to remove this part, clean it up and regrease it. My experience tells me this needs to be done every 10 years on cars.
Sometimes it's the lock motor that starts to sieze up - another known weak point. Though it still works when energized, the key has to mechanically move the lock motor, which can be difficult.
Yes, they make a special tool for the door panel, but as a DIYer, I simply use a large screwdriver.
