Car Drops When I Hit The Brakes
Old 01-10-06, 08:15 AM
chevyastro4x4's Avatar
Why would my car drop down when i hit the brakes?
91 grand am
Old 01-10-06, 09:06 AM
normally the front will drop and the rear will lift. if you feel it is dropping exessively, you may have bad front shocks/struts. poorly functioning rear brakes will add to this.
Old 01-10-06, 09:12 AM
if i am going slower the 15 and hit the brakes the back wheels lock up sometime. but when going 10 or slower and i hit the brakes the whole car will go down. i think it is the shocks and stunts because if i move the steering wheel back and front the car feels like its going to tip. how hard are stunts to change, shocks are easy, never done stunts before.
Old 01-10-06, 09:35 AM
struts are a little tougher in that they replace the ball joint connection and incorporate the front spring. if you've never done them and don't have acces to a spring compressor for struts you may be better off farming it out to a shop. check your rear brakes ( i'm assuming drums ) for leaking wheel cyl's and proper installation of the leading and trailing shoes.
Old 01-10-06, 06:36 PM
do you know how to get the drums off so i can look at the brakes, haynes manual says they just slide off but i cant get them
Old 01-10-06, 09:04 PM
first of all, MAKE SURE your car isn;t going to fall or you run over. Then make sure your e-brake is off and tap around the lugs with a dead blow hammer. Then make sure you are pulling the drum off squarly. If that doesn't work, spray some penetrating lube around the lugs and keep trying. -Elliot
Old 01-11-06, 04:46 AM
back out the adjusters on drum brakes before trying to remove the drum. if badly worn, you would have to turn the adjusters quite a bit.
Old 01-11-06, 05:09 AM
where are the adjusters, because i cant find them on the back it pretty flat.
Old 01-11-06, 05:22 AM
under a rubber cover
They should be on the backing plate maybe coverd by a rubber cover just pull cover off and use a screwdriver or brake spoon.
