try to figure this one out...
Old 01-10-06, 12:14 PM
My sister has a 99 Taurus. The "door open" signal stays on all the time and therefore the domelight does also. I went and played with it. Found out if you press in the top of the rear drivers side door it shuts it off. But, it comes back on automatically when you open any door and must be repeated. Thanks to any suggestions. Currently the bulb is out of dome light.
Old 01-10-06, 04:31 PM
remove the jamb switch from the offending door disconnect the wire and see if that solves the problem. if so, replace it. if not, ya got me
Old 01-10-06, 05:43 PM
couldnt find it
normally it is that little button in the door jamb by the hinge.(right?) Well I could not find the darn thing on the front or rear doors Very confusing.
Old 01-10-06, 06:12 PM
Spray some WD-40 on the latches of all the doors. That's the typical fix.
Old 01-11-06, 06:54 AM
ok,
i will try that and let you know in a few days
