noise in back left fender
Old 01-11-06, 04:50 AM
Question noise in back left fender
1994 taurus wagon, when i start the car im hearing a noise in the back left fender area behind the spar tire. its like a relay or a motor that is clickingon and off. after awhile it stops. any ideas thanks
Old 01-11-06, 05:17 AM
Noise
There is a fuel pump shutoff back there that might be clicking.
Old 01-11-06, 05:34 AM
Don't know how the Taurus is set up, but could it be the power antenna trying to go up or down? My Camry does the same thing. The antenna motor runs briefly when you start and stop the engine, but the antenna itself is slightly bent so it doesn't go up or down.
Pecos
Old 01-11-06, 05:39 AM
yep
Yep the LX did have that option so that might be it also.
Old 01-11-06, 05:56 AM
my fuel pump switch is on the right side, this positivly on the left side i removed the spar and there is a black box mounted on the inside support for the spare tie it has a cluster of wires that seem to plug into this and i can feel it clicking
Old 01-11-06, 06:19 AM
vapor storage canister
If it is under your spare tire the book shows it to be a vapor storage canisterit does have wires going to it as well as some hoses.
