Auto Remote Control
Old 01-17-06, 06:33 AM
W
Thumbs up Auto Remote Control
I have a Lexus RX300 year 2000.
When I use the remote control to unlock the doors, all doors unlock except the drivers door.
Any help appreciated.
Old 01-18-06, 01:33 PM
question
You state the doors will not unlock how about lock do the do that?Does the normal lock work OK?
Also does your system lock all doors when you start driving and if so does that work?
Old 01-19-06, 01:12 PM
W
Remote Control
While using the remote to unlock the doors, all doors DO unlock except the DRIVERS door. Same thing when locking with the remote. All doors lock when the car is in motion.
Old 01-19-06, 01:55 PM
getting complicated
OK we have ruled out that the door lock motor is bad or it would do nothing.
The system runs thru a few relays.It is possible that a relay has gone bad and it is also possible that a wire has broken (wire break is probably in the door hinge area).It could be the relay control also.This is going to require very extensive trouble shooting and you will need a good scematic of the system.
Wish it were something simple but todays cars are not like your grandfathers Oldsmobile. Also the door lock switch could be sticking spray WD-40 into it.It is the part that the door locks into when it closes.this might help.
Old 01-19-06, 05:05 PM
W
Remote control
Thanks for your guidance, Michael
