System Lean
Old 01-21-06, 01:52 PM
System Lean
1999 Isuzu Rodeo; automatic;6 cylinder;SUV
Car excelerates to approx. 2000 RPM on start; then come down to zero and shuts down unless you apply gas. Runs okay until stop, when it drops off and trys to shut down again.
The fuel system is running lean. Got 3 readings on Adv.Auto Sytem: (1) PO171 - System is too lean on bank 1; (2) PO174 - System is too lean on bank2; (3) PO303 Missfire on cylinder 3.
Have replaced fuel filter and ran STP Injector cleaner through system.
Thought next step was to replace oxygen sensor(s), but discovered I needed 4 of them at $50 each. How do I test them, or am I on right track.
Old 01-21-06, 03:30 PM
Don't shoot the messengers
They are only telling you what they are sensing
You've got other issues
BUT...how many miles are on the O2s?
After about 60K it's not a bad idea to replace them anyway
The quality degrades with the miles
It's more likely a fuel pressure, throttle position sensor, or MAF sensor issue
Old 01-21-06, 03:44 PM
New guy's Avatar
Before replacing O2 sensor, check the intake manifold gaskets for vacum leak, they do leak due to bad gaskets and will set system lean code.
Trackbacks are On
Pingbacks are On
Refbacks are On
