1990 pont. grand prix 3.1 wont start,no fuel
Old 01-22-06, 06:43 AM
reyes45's Avatar
A friends`90 Grand Prix will not start. He says that it was running fine the night before and when he went to start it in the mornning it didn`t start.
It has spark but no fuel. I jumped the fuel pump test lead and the pump works. It gives 46lb. of pressure but without the jumper wire the pump won`t operate when you turn the key or crank the engine. also, I connected a test light to one injector plug and cranked the engine and I got no pulse. I already checked the relay by the master cylinder ,all fuses in the underhood and under glove box. They all check out fine. Also checked fussible links under relay. I`m stuck. Heard something about oil pressure switch. PLEASE HELP.
Old 01-22-06, 08:13 AM
chevyastro4x4's Avatar
Can You Hear The Relay Chick When You Turn The Key On?
Old 01-22-06, 09:31 AM
reyes45's Avatar
No, Icannot hear a click. Ichecked the harness plugs with a volt meter and found there is no changes on possitive or ground leads as I turn key on and off or in crank. Thank you for your reply.
Old 01-22-06, 11:07 AM
if you cant hear a click or a humm i would replace the relay
Old 01-22-06, 11:23 AM
Grand Prix Won`t Start
Had one last week samething . fuse blew in power box under hood
Jesse
Old 01-22-06, 05:20 PM
does it have a collision switch in the rear ?
Old 01-23-06, 08:00 PM
New Member
I had a jimmy with similar symptons it ended up being the ignition switch.
