Help with my 454 engine in a Chevy Monster Truck
Old 01-22-06, 09:04 AM
It wont start....the engine turns over and we have changed the spark plugs. We think it may be the distributor....How do we test it to see?
Old 01-22-06, 09:31 AM
454 won`t start
I have found that if you are getting fuel, it is either ignition modual ,coil , or coil wire ,sometimes fues link blown.
Good luck Jesse
Old 01-22-06, 10:44 AM
LouBazooka's Avatar
i agree most likely it'll be the ignition module located within the distributor in 92' - 99' chevys.
Old 01-22-06, 03:43 PM
F
was it running before your post ? is this a new build ? what distributor are you using ? are you using oem ignition or aftermaket ? do you have any spark at the plugs ? post back
