2000 ford f350
Old 01-22-06, 12:21 PM
B
Cool 2000 ford f350
have a 2000 ford f350. jumped a friend off today, now the radio and parking lights and running board lights will not go off without disconnecting the battery cables. what to do?
Old 01-22-06, 11:38 PM
Z
maybe you had this problem before and they were on before you jumped it and that is why it needed jumped?
Old 01-27-06, 08:32 AM
Exclamation Same problem in a 2000 Ford Expedition
My Brother has the same problem in a 2000 Expedition but he didn't jump anyone. the battery is disconnected and the dealer says MAYBE....it's the GEM Module...They want to replace it for $350 with no gurantee?????
Old 03-18-07, 02:38 PM
Disconnect
Have you tried to disconnect the batteries to reset the PCM?
Old 03-18-07, 02:55 PM
HotxxxxxxxOKC's Avatar
If this is a diesel F350, you probably damaged your ECM by doing so.
Old 03-18-07, 04:29 PM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Concur; good possibility you fried something.
FWIW, the following is the jump start procedure for late model F-Series Ford pickups from the towing "Bible". Even though you were the jumper and not the jumpee, the fact there are these restrictions would indicate that strict adherence to procedures are necessary to avoid problems. We never, ever jump from the truck; we always use our portable box which has a constant 12.5 volt (approx) vice the 13.5+ volts that a running vehicle puts out. Here's the procedure:
"When jump starting the vehicle you MUST do the following:
1. Turn on the heater blower on both vehicles to HIGH.
2. If the vehicle has an automatic climate control, set function to defrost position.
3. Ensure that all other accessories are OFF.
4. Follow the general jump starting procedures.
5. Reduce engine speed to idle before disconnecting jumper cables."
I cringe when I see someone in a parking lot with their jumper cables out and connected to a newer vehicle.
