Please Help
Old 01-24-06, 05:08 AM
Unhappy Please Help
I have a 99 Ford Contour with a transmission sticking. When I accelerate, the transmission sticks, but then it jumps into gear. My Overdrive light is also coming on, and I was told that my overdrive is gone. So, I am guessing that I need a new transmission. The fluid levels were checked and it has transmission fluid.
What do you think? Please give me advice. Thanks in advance.
Old 01-24-06, 07:38 AM
C
How does the tranny fluid smell? Does it smell burnt or can you recal when it was changed last? Good news is you might not need a new one, the may be able to rebuild your current one. Good luck.
Old 01-24-06, 08:57 AM
check for proper fluid level, fill if needed, if it smells burnt, exchange fluid alltogether, test drive, see what it does,
