wipers stuck in the veritcal position
Old 01-25-06, 06:14 AM
2000 buick regal wipers stop in the vertical position. i can use them but when I stop them the stay in the vertical position. how do i fix this?
Old 01-25-06, 10:45 AM
pgtek's Avatar
sound like you need new motor
the parking stop is not working
Old 01-25-06, 03:38 PM
where is it located and how do i change it?
Old 01-25-06, 06:55 PM
What you need is the wiper crank arm, the motor is fine. It is easy to replace once you remove the wiper arms and the cowl cover, its on the passenger side. I don't have the correct proceedure here at home to post, but I can get it from work. You basically take one bolt out, and the crank arm comes off. There is a certain way to reinstall the new one to verify the wipers and the crank arm are timed correctly. If need be, I can provide that info if the new crank arm does not come with instructions. This crank arm is gold anodized in color and is about the size of your wife's palm of her hand, not that I would know the size of her hands, .
Old 01-25-06, 08:43 PM
thank you i will get one tomorrow.
Trackbacks are On
Pingbacks are On
Refbacks are On
