Pontiac Grand Am Window Handle
Old 01-27-06, 05:59 PM
Smile Pontiac Grand Am Window Handle
Help me I am a very amateur do it yourselfer. I am trying to replace the passenger door window and I have almost removed the inside panel but I cannot figure out how to remove the window handle. Please point me in the right direction.
Old 01-27-06, 07:29 PM
It should be held on by a simple spring clip. Easiest way to remove is to get a removal tool at any auto parts store. They are usually very inexpensive.
Old 01-27-06, 09:32 PM
ASEPartsman
Some Fords use a screw to hold the handle on. If this is the case pry the "cover" off using a screwdriver on the base (the wide part connected to the door.) This will expose a screw. If it uses a spring clip like Goldstar mentioned, you can get the tool from a parts store for about $10. Or a shop rag works good. Slide the rag in between the door panel and window handle and slide around until clip comes off.
Old 01-28-06, 02:13 PM
rag
Like was said if you have a clip style a shop rag works well.
Trackbacks are On
Pingbacks are On
Refbacks are On
