How do I seperate the fan from water pump
Old 01-29-06, 11:23 AM
satellite guy's Avatar
I removed my water pump but can not get the fan clutch off. There is one nut which attaches directly to the pump, but I can't get it loose. Any ideas? Thanks in advance
Old 01-29-06, 12:22 PM
ASEPartsman
What is the application?
Old 01-29-06, 12:40 PM
It's on a 2001 Land Rover Discovery.
Old 01-29-06, 02:11 PM
billys68ss's Avatar
The best way to do that is with the pump still on the vehicle, but since you have it off already, Do you have the correct size wrench for the large nut on the fan? If so then put some type of holding device, I use a pry bar or large screwdriver, whatever you can get in there, in where you can hold the shaft of the pump and then use your wrench to loosen the fan. They can be very tight, but it will loosen. Be sure that you are turning the correct direction. Some fans have reverse threads.
Hope this is helpful to ya,
Billy
Trackbacks are On
Pingbacks are On
Refbacks are On
