87 Grand Am Stalls When Put In Drive
Old 01-29-06, 06:45 PM
rrw
rrw is offline
1987 GRAND AM STALLS WHEN PUT IN DRIVE. 3 OTHER MECHANICS SAID TO REPLACE TRANNY AS IT APPEARED TO BE LOCKED UP INSIDE. SO WE REPLACED TRANNY. CAR STARTED OK AND DIDN'T STALL WHEN PUT IN DRIVE. APPEARED TO DRIVE FINE ALSO. A FEW MILES DOWN THE ROAD AFTER A SHORT STOP AT STORE IT STALLED AGAIN WHEN PUT IN DRIVE AND ORIGINAL PROBLEM IS BACK EXACTLY AS BEFORE. ANY IDEAS VERY WELCOME
Old 01-29-06, 07:31 PM
will it go into gear without dying after it has set for awhile?
what size engine?
Old 01-29-06, 07:38 PM
rrw
rrw is offline
what size engine?
It won't go into gear without dying now at all. Engine is 3.0 ltr .
Old 01-29-06, 08:08 PM
suggest seeing a shop for a diagnossis I would suspect it would be an electrical problem either in the electronic engine controls or damaged wiring harness it could take a while to find.
was the torque convertor replaced with the transmission?
Old 01-29-06, 11:54 PM
rrw
rrw is offline
THANKS. WE'RE THINKING ELECTRICAL TOO AS IT HAS SOME LIGHTING PROBLEMS THAT SEEM TO BE CAUSED A SHORT SOMEWHERE TOO. TRIED TO FIND OUT WHY THE SHORT BUT IT'S BEING VERY HARD TO FIND TOO. TORQUE COVERTER WAS REPLACED WITH TRANNY THOUGH.
Old 01-30-06, 04:25 PM
sounds like it may be that the torque converter isnt unlocking try unplugging the four pronged plug on the radiator side of the trans then try it. ive seen this alot on those cars
