Replace serpentine belt
Old 01-30-06, 06:59 PM
Well now that I have purchased the P/S pump and hoses, I decided while I am at it replace the belt. (1995 olds 88 royal 3.8 ltr no supercharger)Now at the time I had a few brewskies in me and thought no problem since I needed to remove the belt to change out the pump. But now I look at the belt, It seems that I need to get it over (or under and through) a motor mount. Is there a easy way to feed the belt and get it on. Also is there a tool that I need to purchase for a crap load of money that I will only use once, or is it just brute strength that will work? Also will the tension pully spring on me when I remove the belt. Thanks for the info. I am not that great with repairs since I am a professional beer drinker. Thanks again.
Old 01-30-06, 07:38 PM
the_tow_guy's Avatar
This should give you all the info you need, pd:
http://www.autozone.com/servlet/UiBr...3d8017f8bc.jsp
