Heats up - cools down !
Old 01-30-06, 07:50 PM
My 1992 Toyota Paseo just started acting up. When I accelerate - the temp guage climbs up - almost to the danger zone! As soon as I come to a stop at a light, it cools right down to below the halfway mark (where it usually always stays). What could be causing these "jumps"? Thanks in advance!
Old 01-30-06, 08:08 PM
ASEPartsman
Thermostat may be sticking. Try replacing it, and flush and burp cooling system.
Old 01-31-06, 04:32 PM
Lugnut's Avatar
Are you sure you don't have that backwards? Temps usually drop when driving, and go up when stopped.
Old 01-31-06, 07:56 PM
how big is the grill on that car?
Old 02-01-06, 03:43 AM
a restricted or plugged radiater often causes overheating only when vehicle is under a load and may run at a normal temp at idle, if the thermostat and coolant flush doesnt solve your problem suggest checking the radiater.
Old 02-01-06, 08:42 AM
Could also be that the water pump belt slips but only at higher speeds. Quick and easy check...
Trackbacks are On
Pingbacks are On
Refbacks are On
