Crown Victoria Performance
Old 02-06-06, 07:47 AM
Is there any easy way to get more horsepower out of the Ford Crown Victoria Police Cars, like a turbo, supercharger, or is crate motor the only way to go?
Did these cars ever come with a standard transmission?
Old 02-06-06, 10:17 AM
an engine should be built specifically for running a supercharger or turbocharger as there usually run lower compression and may also have larger ring gap specs.
you might be able to install a power module or chip depending on year that would help, along with a more free flowing exhuast system and headers.
Old 02-06-06, 10:19 AM
The thing is is that I dont own a crown vic yet, but I am going to be buying one with 6 months. Hopefully it will be one of the police interceptors.
Old 02-06-06, 03:23 PM
warning warning
A friend of mine bought a crown vic police interceptor from the Auston police department.
I had quite a conversation with him about his car and as cool as it is beware these cars are driven hard.My advice would be to get one from a constable,or sheriff not just a reg police car.
Also there are extra wires and such for the lights that they remove and they just chop them off and tape up the ends.
Also they come with no spare tire.
His is already broken down he was doing a high speed pass trying to pass someone on the interstate punched the gas to the floor and heard a bang as it turned out his trannie went belly up.
If you want plain jane no carpet,vinal seat,cant open back doors from inside kind of car the police car is for you.
Just beware the cars are driven hard and many sit for hours just at idle.
Old 02-06-06, 03:51 PM
not that i'm a ford performance expert, but i belive the only way to get one to move is the installation of a big block chevrolet engine....
Old 02-06-06, 04:09 PM
Bubba Bob
Yeah, but he wants his Crown Vic to move w/o a tow truck
Old 02-06-06, 05:19 PM
v8driver's Avatar
Usually its the chevy, towing the other...
But as for the police car..... like van said, they are run hard, they do carry out the regular maintenance, most either set running for hours on end, and then the heck run out of them, or spend most of the time getting the heck run out of em... thats why they have oil coolers on them. You can do a performance cam, performance intake, injectors, a chip, etc.
Old 02-07-06, 06:17 PM
Thanks for all the advice guys.
The only time I have ever seen a chevy tow truck, it had a ford towing it.
Old 02-08-06, 06:03 AM
You may want to hook up with these guys:
crownvic.us
crownvicnet
Old 02-08-06, 07:58 PM
Exclamation our442
Ford towtrucks are for show .GMC is for go get the job done.
Old 02-10-06, 04:05 AM
its
Old 02-10-06, 04:54 AM
it is what it is. it's tough for a chevy guy not to chuckle when someone asks how to make a ford run.
Old 02-10-06, 03:38 PM
Does anyone know, did the Crown Victoria ever come with a standard transmission?
Old 02-10-06, 06:20 PM
LouBazooka's Avatar
you mean manual transmission ? no i dont think so, never seen one.
Old 02-11-06, 06:32 AM
yes, I mean manual. Ok thanks anyways.
Old 05-04-06, 03:39 PM
I was told that instead of doing a whole engine replacement which would take alot, and I mean alot of work, that putting a blower on there would be a lot easier and cheaper.
Old 05-05-06, 03:28 AM
while you can probably get a blower and run it at low boost pressures without a problem not sure you are going to gain much performance, to run higher boost pressures the engine needs to be built specifically for running a blower.
as per cost you could probably build an engine that has more hp that is naturaly aspirated for about the same price as a blower setup running low boost pressures on a stock engine not factoring in labor as the engine would require more labor.
Old 05-05-06, 05:22 PM
I've never seen an interceptor with stick, and I've driven a few.
It's tough enough balancing a cup of coffee, a donut (had to say it), and answer the radio without have to fool with a stick shift.
Trackbacks are On
Pingbacks are On
Refbacks are On
