Can radiator leak be repaired in place?
Old 02-06-06, 07:22 PM
1997 Ford F150 4.2L V6 50,000 miles
Radiator is leaking transmission fluid. Leak is where the tubing enters the radiator, right at the big nut/radiator joint. I think I bent the tubing too much and cracked the solder (or braze).
Is there an in-place repair compound? Or has the radiator to come out?
Thanks.
Old 02-06-06, 08:21 PM
LouBazooka's Avatar
Thanks.
There's a couple products to fix this kind of mishaps ( epoxy sealants ) , if i were you i'd take the rad out and take it to a radiator shop, radiator is easy to pull out on pickup trucks ( at least on chevys ).
You might as well get a rebuilt one with core exchange too, usually very affordable, or just have them fix and clean the old one, prices should be about the same.
Old 02-06-06, 08:57 PM
Do you recommend taking it out because epoxies are not a permanent fix? Thanks.
Old 02-06-06, 09:10 PM
LouBazooka's Avatar
I meant take it out so you can take it to a shop to be welded or exchanged, epoxy repair would be hard to call , tranny fluid is under pressure/temperature variations all the time.
Without mentioning some epoxy or glue getting into the transmission.
Old 02-07-06, 05:16 AM
Thanks. It will be my first radiator job. With your encouragement I will pull it out.
