96 Maxima, radio/dash panel removal
Old 02-07-06, 01:51 PM
R
I am trying to figure out how to take out the radio, and or the center part of the dash area where the heater/a/c controls are, cigarette lighter, etc. The radio is a replacement (not factory), and I cannot figure out how to get it out. I can take out the cigarette ligher and ash tray, but the rest of the console area won't move. Are there screws somewhere? Any help would be appreciated.
Old 02-12-06, 10:17 AM
curt o.
96maxima
Take a flat end screwdriver and pry open at bottom of center ac vents, slip that out the way and the rest you will be able to figure out yourself.
Old 02-13-06, 11:09 AM
R
Curto O, thanks for replying. I figured it out yesterday. You are correct, pry out the plastic frame around the 2 vent openings, it gets you access to the 2 screws holding the top part of the cluster in place. You pry open the cover surrounding the transmission shifter, take out the ash try and get access to the 2 screws holding the bottom end of the cluster. Need to be carfeful not to crack any of the plastic. Thanks.
