1007 taurus 3.0l trannie line
Old 02-07-06, 03:41 PM
I
the trannie line going from the trans to the radiator rusted at one of the hold-down fittings. can i cut it and use a compression fitting or could i get away with a rubber hose clamped at each end, as a temporary fix for a short travel.
thanks
bill
Old 02-08-06, 03:37 AM
B
the correct way to fix it would be to replace the line you may be able to temporarily use clamps and a piece of hydrualic hose but this will usually start leaking again in the future.
Old 02-08-06, 10:14 PM
O
Thumbs up our442
Originally Posted by isetheby
the going from the trans to the radiator rusted at one of the hold-down fittings. can i cut it and use a compression fitting or could i get away with a rubber hose clamped at each end, as a temporary fix for a short travel.
thanks
bill
I have used compression fittings to repair trannie lines and never had leaks for life of car 5 years I had said car .
Old 02-09-06, 05:14 AM
K
I agree to stay away from rubber and use metal for the fix... either splice in a new line with compression fittings, flared ends, or a completely new line.
