93 Cavalier Turn Signal Help!!!!
Old 02-08-06, 08:59 PM
The turn signals won't flash. I have tried putting in new bulbs in all four. I have tried putting in a new flash fuse, Nothing works. Can somebody plllease, please, HELP ME!!!!??
Old 02-09-06, 03:15 AM
do they light up but dont flash or do they not even light up?
if they all light up just dont flash did you change the right flasher as they are usually 2 one for the hazards and one for the turnsignals.
does the hazards work?
Old 02-10-06, 09:40 PM
they light up, they just dont flash unless i do it by hand with the lever.
how do you tell the differance between the two flashers?
Old 02-10-06, 10:43 PM
they are probably identical however the turnsignal flasher is usually under the driver side dash and not as easily found as the hazard flasher you can turn your hazards on and if they work ok you can feel the flasher pulse on and off to determine which one is the hazards.
