1995 Mitsubishi Eclipse, squeaky front end....
Old 02-09-06, 05:38 AM
EHess
The right front wheel of my Mitsubishi Eclipse is squeaking loudly. My friend told me my shocks needed lube where they mount. I see no grease fittings. Is this correct? How do I lube it? The car is driving correctly, so I donm't think anything is broken, but it sure squeaks when that right front goes up or down. Help!
Old 02-09-06, 05:49 AM
silicone spray
Use silicone spray on all the rubber bushings to isolate the one making the noise spray one at a time ,they get old and dry out this is only a temp fix but you can spray and it will last for awhile.
Down the road you might want to replace the rubber bushings.
Old 02-09-06, 01:15 PM
LouBazooka's Avatar
it may be time for new shocks on this '95 also.
