How to read codes!
Old 02-09-06, 01:21 PM
bwtunnell
Arrow How to read codes?
I have a 1990 chevy Cavalier Z24 with a 3.1L engine. I'm having problems starting it after I washed the engine! could be a lose ignition wire or what ever but I want to find out for sure! Can anybody help? If it helps my blower quit on me too!
Old 02-09-06, 05:05 PM
Lugnut's Avatar
What are you asking? How to pull codes or how to start the car?
Old 02-10-06, 05:53 PM
O
Lightbulb our442
check fuse for blower and you may find some engine part is on same line as blower.Check all fuses And make sure engine is well dry.3.1 hates moisture.
Old 02-13-06, 08:52 AM
I
Pulling codes won't help with the blower motor!
Old 02-13-06, 04:00 PM
diagnosticmonke
Wd- 40
Theres only two things ive found to use WD-40 for. One is for drying out moisture from ignition and engine components and the other is fishing. The whale oil base sure attracks them fish.
