spark plug wires
Old 02-12-06, 04:41 PM
Unhappy spark plug wires
I have an F150 Ford pickup 4.6L 8 I was trying to remove the passenger side rear plug and could not get the wire off. I took it to pep boys and they could not remove it. I intended to replace the 100,000 mile plugs and wires.
Any suggestions
Old 02-12-06, 05:00 PM
B
seeing how you are replacing them, try to get the wire to turn in the plug hole first by twisting it back and forth then just give it a good pull if it breaks you may have to use needle nose pliers and a pick to remove pieces of wire use a small mirror to look down the hole to make sure youve got all the plug wire out of the plug hole and it is a good idea to blow it out with compressed air before removing the plug.
