How can I get parts interchange info
Old 02-13-06, 08:48 PM
Negoshe8n
I'm looking for valve springs that have a higher seat pressure for my 3.0 dodge\mitsubishi motor. I want to find out what other motors use these springs in the hope of finding ones with a higher seat pressure.
Old 02-14-06, 03:42 PM
P
I'm not sure that's a good idea. That said, gunsmiths just use a slightly longer spring to accomplish your objective. Maybe one of the experts will weigh in on this.
Old 02-14-06, 05:04 PM
F
are you having a float problem ? have you changed the cam? have you pulled one to check the existing seat pressure at installed hight ? if you can supply some specs like inner and outer diameter, pressure at a given hight maybe there is a substitute aftermaket spring. first the end goal needs to be established. it is quite possible a new oem spring would solve the problem for you.
Old 02-14-06, 08:30 PM
O
Lightbulb
You can try a raceing type springs that will be higher.
