92 Olds Cutlass Ciera Turn SIgnal
Old 02-14-06, 08:00 AM
Hope this doesn't seem like too stupid a question, but I can't figure it out myself. Right turn signal works fine, left one does not blink, just stays on. Both outside lights come on. Is this a bulb or the flasher? If it's a bulb, which one?
Old 02-14-06, 08:16 AM
I can't remember if that's a combination bulb or not
If they go 1/2-way (1 filament), it'll do that on some cars
(some cars the indicator flashes like crazy)
I've had a few Cutlass' and can't remember if it just stays on when there's a problem
Easy enough to check
Pull the bulb and check both filaments
...or if there's only one, than that's not it lol
I'm not one for throwing parts at a problem, but if you get a good bulb and that turns out not to be the problem, it's a good idea to have a spare in ther glovebox
Old 02-14-06, 08:35 AM
The rear light is turn signal, tail light and brake light, so that sounds like the place to start.
Old 02-14-06, 08:42 AM
Yeah, if that's the case I'd put cash on it being the bulb
Old 02-14-06, 09:16 AM
Thanks for your help slick.
Old 02-14-06, 07:52 PM
does it work with 4way flashers. If so I bet it will be flasher.
Old 02-14-06, 09:13 PM
Never thought to try that, I'll do it as soon as I hit the garage tomorrow morning.
Old 02-14-06, 10:06 PM
Allso check Brake lights most are on same line.
Old 02-15-06, 10:18 AM
Haven't tried the brake lights, but the hazards do come on, so it's looking like the flasher. Anyone know where it is in this car?
Old 02-15-06, 11:32 AM
You will find it under the dashboard neer stearing wheel.
Old 02-15-06, 11:43 AM
Allso make sure front signal lights up as well they are all on same line. If one front signal light is out signals will not flash on that side. Good luck.
Old 02-15-06, 12:27 PM
easy to find
Turn on the good signal the right one I think you said and listen and follow the sound.
Old 02-19-06, 05:10 AM
I thank you all for your help, the point is now moot, the car got totalled out Friday.
