turn signal shorting out
Old 02-14-06, 12:32 PM
1996 Ford Ranger. My turn indicator seems to have a short or a bad switch. It works when I it goes down to turn left but when I click it up I need to push it real hard to get it to blink. And also, sometimes my headlights will flicker on and off when i try to push up to make my blinker blink. This makes me belive it is a short in the column. Can "I DO IT MYSELF" or should a $75 an hour mechanic need to look at it. Thanks for the help...
Old 02-14-06, 01:30 PM
probably a bad switch
yes you can do it yourself
get a haynes manual and follow the directions
especially note the airbag cautions if you have one
it should be an easy job
and you probably have a worn switch with an open not a short.
Old 02-14-06, 01:44 PM
I would lean towards the worn switch also
It might be worth checking at autozone.com for instructions
The may have them posted there
Old 02-14-06, 02:44 PM
Ford is easy to do. I just replaced the bearings in a 96 ford column.
