Ford Taurus major electrical issue....
Old 02-17-06, 05:45 AM
A friend owns a 2001 Ford Taurus station wagon.... all of a sudden his power door locks, dash lights, radio, windshield wipers, rear window defroster etc. all quit working. He checked the fuses, all good. He swapped a couple relays with each other, problem still there. What do all these have in common?? Any ideas would be appreciated!
Old 02-17-06, 09:41 AM
Michael's Avatar
I have a 1996 Taurus and had the door locks, radio and wipers act up. It turned out to be the MLPS that is mounted on top of the trans. It is the switch that is under the arm that the shift cable is connected to. Changed the switch and all is well. Check out www.rockauto.com good parts and prices.
Old 02-17-06, 05:46 PM
ASEPartsman
It sounds like a G.E.M. module. These are mounted under the dashboard and the Taurus had a problem with water leaking in there and the module going bad.
Old 02-17-06, 09:00 PM
Yes Mercury Sable hes the same deal.
