simple oil change question
Old 02-18-06, 11:59 AM
dkpbxman's Avatar
When draining the oil, is it better to open the oil fill cap on the top of the engine so the oil can flow more easily?, or does it not matter?
Thanks for any answers,
Dan
Old 02-18-06, 12:25 PM
New guy's Avatar
If you want to, technically it'll drain easier but I never notice any different, just heat the engine up to normal temp, that will helps it drain easier.
Old 02-18-06, 01:15 PM
Received 1,262 Upvotes on 1,203 Posts
I agree - I have found warm oil makes more difference than anything else.
Old 02-18-06, 01:54 PM
G
Received 2 Upvotes on 2 Posts
I remove the cap and the dipstick. It is a reminder that I need to put oil back in - just in case my old timers disease kicks in.
Old 02-18-06, 02:07 PM
dkpbxman's Avatar
Good point
Makes sense. With my luck, I'd have a "senior" moment and try to drive to the store without any oil.
