crown vic brake shift lock
Old 02-19-06, 10:47 AM
my '94 won't shift out of gear; the problem may be the brake shift lock switch. 2 questions: I was advised there is an override for this, ususally on steering column, but for 94 model it is elsewhere. Where is this?
Second, where do I find the brake shift lock switch so it can be replaced?
Jim
Old 02-19-06, 04:49 PM
Have someone look at brake lights while you press the pedal if they not working theres the problem the switch is located on the top of the break pedal pretty easy to change. just pay attention to where the plastic bushings go back. good luck!!!!
