Voltage Drop
Old 02-20-06, 07:52 PM
chevyastro4x4's Avatar
Voltage Drop
What could cause such a voltage(from 14 to 11)when i push the brakes?
it on a 91 grand am 2.5l
Old 02-20-06, 08:38 PM
Brakes takeing to much power (short) or alternator is weak under load.
Old 02-20-06, 09:01 PM
Need more info
What is voltage at idle? Does it only do it when brakes are pushed? Do you have a trailer connection?
Old 02-20-06, 09:04 PM
alt was tested and it tested good under a load, batt is good to. could it be the brake switch
Old 02-20-06, 09:06 PM
at idle its 14.3, when the blinker is on the voltage drops about a volt, no trailer connection
Old 02-21-06, 05:34 PM
That close to norm. check all engine and body grounds.
Old 02-21-06, 07:30 PM
Ok Thanks I'll Try That And Get Back To You.
Old 02-21-06, 07:40 PM
Where are you checking the voltage from ?
Old 02-21-06, 08:21 PM
at the alt and batt
