Honda 2000
Old 02-21-06, 06:36 PM
daniel55's Avatar
Honda 2000
How do you reset the maintenance required light?
Honda odyssey 2000 86K
Old 02-22-06, 04:37 AM
daniel55's Avatar
Where can lok to find fault codes for he honda?
Old 02-22-06, 09:13 AM
daniel55's Avatar
found, another question
alright I found the codes.
To reach the EGR valve on this Honda odyssey is it from the top or from the bottom. I have not located it as of yet so this may be a dumb question.
Old 02-22-06, 03:08 PM
daniel55's Avatar
I just had a full time mechanic fix our car
Short on time, so I took our van to the professional. He found my EGR passage ways restricted. Cleaned them and all is good. He did suggest that the oil I use 15-40w may be the major contribuitor and suggest I use 5-30w so I guess I will switch.
Old 02-22-06, 09:19 PM
LouBazooka's Avatar
why were you using 15-40 w ? heavier oil lubricates less, use the recommended weight on your owner's manual.
Old 02-25-06, 07:22 PM
O
With OBDII scanner with erase mode.EBay has them for around $40.00
