Check Engine Light On '98 Nissan Altima
Old 02-23-06, 01:11 PM
My '98 Altima has a check engine light and threw a P1448 code. The code says EVAP Canister Vent Control Valve (Open).
A few questions:
1. Where is the valve?
2. Is it easy to get off?
3. Is this a repair or replace item?
4. What is the part number? (Nissan dealership says there are several valves on the EVAP system)
Thanks
Old 02-23-06, 01:22 PM
LouBazooka's Avatar
A few questions:
Thanks
Emission Canister is usually located under hood on either extreme right/left towards front of vehicle on older vehicles though,1998 Altima I'm not sure but if you can locate it , you should be able to fix it.
Old 02-24-06, 05:37 AM
I found the valve. It is bolted to the cannister..........under the car, behind the driver's side rear wheel. It is a plastic square-shaped canister rather than the round, under the hood variety.
Thanks
Old 02-24-06, 09:40 AM
Thanks
Part no. will be on valve
Old 02-24-06, 11:02 AM
I'll check for a part number when I get home.
I called several Nissan dealers as this is a dealer-only part. Apparently there have been problems (moisture, crud, spider webs) with the valve and even the canister. Nissan wants $117 for the valve - scares me to think what they would want for the canister!
I'm wondering if I can salvage the valve via WD40 and repetitive manipulation?
Old 03-05-06, 10:21 PM
Yes WD40 and air will clean out valve.
Trackbacks are On
Pingbacks are On
Refbacks are On
