2001 Ford Explorer- Starting problems
Old 02-25-06, 01:25 PM
frza21
I have a 2001 Ford Explorer Sport 4.0L 6cylinder. I have owned this since it was new and it has just started give me a little problem when i start it. When i turn the key, i just a fast clicking noice. After i try a few times it barely starts. This just started happening last night. Could it be the Battery? i have an amp and speakers in it and have never changed the battery. Or could it be the starter?
Old 02-25-06, 01:41 PM
My gess is battery. Check with volt meeter and check voltage at battery with engine running. 13-15 is norm. If lower replacs alternator and if volts are in range replace battory. Hope this helps.
Old 02-25-06, 02:20 PM
battery
I concur a 2001 vintage battery is very near the battery grave yard Batterys now days last abot 3-5 years
Stick a new battery in clean the posts this should fix your problem and you will have a new battery good for another 3-5 years.
