help!
Old 02-25-06, 04:01 PM
help!
I have a 1999 Pontiac Bonneville SE and last night it was working good, and today in the morning when I used it, the signal handle doesn't come back when I tur left, when I turn right it comes back but not when I turn left, I have to turn it back manually. Any Ideas?, did something broke or what happened? Thanks
Old 02-25-06, 04:55 PM
usually it is due to a problem in the switch itself it will need to be removed for inspection and replaced or repaired if necassary, on older models the cancel springs could be replaced and fix that specific problem not sure on your model.
suggest taking to a shop for repair as it probably requires airbag removal to gain acess to the switch.
Old 02-25-06, 07:06 PM
Tab on signal plate under stearing wheel bent or broke.Will need to replace it.Make sure you unhook battory to dissarm air bag and wait 5-10 min.
